grades of wire
Old Sep 11, 2003 | 11:17 PM
BIGJsTA's Avatar
grades of wire
I'm in the process of re-wiring the interior of my car, pretty much from the ground up, to get rid of some ugly stuff done by the previous owner and his "alarm" what do you guys think about wire grades? I have access to large amounts of free THHN wire, (the kind used in houses), but painless wiring likes to brag about how thier THX wire is worth the price difference, and i gather that stock, the wires are grade GPO.
Think the grade really makes a difference? Should i head to a yard, pop the cash for a spare wiring harness to use for wires? or should i just use the THHN house wires? I guess the only real difference is in the insulation eh? And inside the interior i doubt it would matter.....But if one of you guys tore off your console and found a bunch of THHN house wire, would you think it a ****y non-proffesional job?
Old Sep 14, 2003 | 01:06 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
if you really feel like undertaking this task (believe me it sucks, and i'm an electrician) good luck, find out what type of current your stuff will be pulling, you need to be using certain gauge wiring and fuses are a must.... this might help you http://www.powerstream.com/Wire_Size.htm
Old Sep 14, 2003 | 07:49 PM
BIGJsTA's Avatar
heh actually i am an electrician as well, that's where i get my access to unlimited supplies of THHN wire (house wires heh)..
I'm just wondering about the actual insulation, if anyone has ever had problems...Like I know THHN cant be used very safely in the engine compartment and going to the fuel pump ect, because gasoline disolves it, when we wire in situations where they will be exposed to oil/gas a different grade of wire is needed. Inside the car though, i dont see the wires taking much abuse...Anyone know what grade factory cars use? GPO?
Old Sep 14, 2003 | 08:03 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
make sure the wire that you use in your car is stranded and not solid core, most of the time solid is used in houses because there is no vibration to break it. stranded must be used in your car for this reason. if it is stranded go ahead, and you wont need much more than 16 or 14 gauge for most of the wiring (except for the starter and alt and some other high current things like the fans).
Old Sep 14, 2003 | 10:27 PM
dans82bird's Avatar
Engine: 302
That's exactly what I was about to say, use stranded wire because solid copper is too brittle and will break in no time from the vibrations in a car. Its not really that critical on the thickness of your insulation or the quality, its just a street driven car, so pretty much any stranded wire will do, just don't use speaker wire like some idiot who had my car before me
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
