Bypass nutral safty switch?!
Old Sep 12, 2003 | 04:36 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
found ouyt that my cars not turning over because of the nutral safty switch. put a B&M megashifter in and didnt connect the other cable, there was no where to put it! can i bypass this? any ideas? i want to hear my new motor run!
Old Sep 12, 2003 | 10:19 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
u can bypass it but it is dangerous, it is there so it cant start in gear, but here goes, locate the purple and yellow wires, and connect them together, that will allow u to start it in gear, if im wrong feel free to correct me anyone
Old Sep 14, 2003 | 08:08 AM
Kontrax's Avatar
Car: 86 Camaro
no need now, i wired in a relay and eveything works great, back up lights and all. 8 dollar fix!
Old Sep 22, 2003 | 05:54 PM
83purplebird's Avatar
I have a simular problem, what 8 dollar part fixed your backup lights and neutral safety?
thanks,
joshe@ev1.net
Old Sep 23, 2003 | 03:59 PM
Kontrax's Avatar
Car: 86 Camaro
you got a buzzing noise under the dash when you turn the key? well i had the problem because i was installing a shifter. theres a purple and yellow wire in the center council, thats what did it for me. have to make sure they are wired up. dont know what color your line is, its different in a few years. i wired a relay to the 2 and it fixed it. you can wire them togeather but thats no good. if you need a new ignition switch let me know, i bought one figuring it was that but ended up being a 7.99 relay.
Old Sep 23, 2003 | 04:45 PM
i was wondering about the relay you got for 8 bucks. what relay would that be?
I have a quicksilver shifter, and just have the purple/yellow wires hooked together at the moment, lets the car run, but i dont have any backup lights
thanks,
Old Sep 25, 2003 | 08:38 PM
Kontrax's Avatar
Car: 86 Camaro
yeah its a radio shack relay, stock # 275-206. solder the purple to # 12 on the relay and the yellow to #8. there will be little numbers on the prongs on the relay. #14 is ground, dont forget to ground it. the green wire is my backup lights, not sure what it is on yours, some wires vary depending on the year of the car. but my b&m shifter came with relays and i soldered that wire to the b&m relays. i made a mistake though cuz my reverse lights are on in park so i gotta reverse the connection. need anymore help let me know.
Veaceonee
Sep 29, 2016 08:15 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
luvofjah
Sep 3, 2015 07:08 PM
