Where is the swith located for the hood light??
Old Sep 18, 2003 | 08:43 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I think my light is staying on when I close my hood. I tryed to find the switch that controls it, with no luck. I had to relocate the light after I installed a STB somehow relocating it has affected when it goes off. It seems like now the hood has to be closed all the way before it goes out or use to go out, like I mentioned I don't think it's going out at all any more. All I did was move the light a couple inches to the side. Someone help!!
Old Sep 18, 2003 | 09:54 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I always thought the light was turned on/off by the parking lights. Thats how it is on some other cars I've worked on(Fiero, Cutlass Ciera)
I dunno, thats wierd.
Did you disconnect it when you moved it?
Matt
Old Sep 18, 2003 | 11:19 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I'm refering to the light that is under the hood that comes on when you open it. Has nothing to do with parking lights
Old Sep 19, 2003 | 01:47 AM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
It is inside the light fixture itself, like a mercury type switch, comes on when hood opens so far...if you changed the angle that it mounts, even a small amount different from stock, it would open or shut at a different hood position than before.
Old Sep 19, 2003 | 08:28 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
That would explain it then cause I bent it up when I moved it over.
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Dialed_In
Aug 20, 2015 01:45 PM
JFry
Aug 19, 2015 01:25 PM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 11:48 AM
