Turn signal ?
Old Sep 26, 2003 | 09:20 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Turn signal ?
I have never had a problem like this before so I am trying to see what ya'll think.
My turn siganls don't flash when I try to indicate I am trying to turn. I finally got my car back on the road and tested all the lights and stuff and everything worked fine. The next day on my way to school I hit the turn signal lever and noticed that the arrow was not on. The normal clicking sound was not heard from the turn signal either. Outside not lights come on... I checked the hazard lights and the arrows come on and the outside bulbs flash when the 4 ways are on. All the other lights work...And the turn signals did work when I checked them the night before. What gives? Bad flasher?
Old Sep 27, 2003 | 09:55 PM
3gc's Avatar
3gc
Car: Z28
It sounds like the flasher possibly came loose if the lights aren't turning on at all.
Old Sep 27, 2003 | 11:18 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Possibly a bad flasher, if neither side works. Check your reverse lights (key on)...if they don't work either, then it's probably just the TURN/BU fuse blown, they run on the same fuse.
Pete
Old Sep 28, 2003 | 06:00 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Pete
I don't have any reverse lights...When I changed transmissions, I never rewired the reverse light switch...That was too much work for lights you don't really need, IMO
Thanks for the ideas
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
