PASS KEY or VATS Ques........
Old Sep 29, 2003 | 01:12 PM
I EAT T/A's Avatar
Car: '87 Camaro
Axle/Gears: 10 bolt, 3.23 posi.
I am in the process of swapping my totaled '91Z components into my '87 LT and am wondering how I'm supposed to find out the resistance of my key chip??? If I've already stripped the '91 of all its interior/dash components. Meaning the steering column is still in the car, but nothing else is.
Please help!!!
Old Sep 29, 2003 | 03:26 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
You could always measure it with a multi-meter......pretty easy. Are you bypassing it?
You probably don't have the key eh? Ask the dealer if you can measure the resistance of the keys that they have, or ask if they know. There are only 7 or so different values so it shouldnt be too hard to guess and check. Most remote start boxes come with them so you could ask a stereo shop what they know for values. Once you know the value, you can put the resistor in there to bypass or get the right key made.
Old Sep 29, 2003 | 06:25 PM
I EAT T/A's Avatar
Car: '87 Camaro
Cool thanks man. I was hoping thats all I had to do for measuring the chip. I do still have one of the keys so, I'll have to measure that *****.
Old Sep 29, 2003 | 06:37 PM
Blue1989RS's Avatar
Car: 1989 RS
you betcha. I'll remove mine when the time comes. The hard ones are the toyota vans with the RF transmitter in the key. There is no way around it except to take a spare key, wrap wire around it and then continue the wires to the tumbler, wrap the wire around it, and then back to the spare key. That couples the RF signal from the spare key in the dash to the tumbler, so the computer thinks the key is in the tumbler. So consider yourself lucky!
Old Sep 29, 2003 | 06:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you going to be putting the computer in the 87 as well? If you are planning on putting VATS into a non-VATS car then you will have to have a computer chip that is programmed to work with the VATS module. There are 15 different codes that GM uses in their V.A.T. systems. They are as follows, (1) 402, (2) 523, (3) 681, (4) 887, (5) 1130, (6) 1470, (7)1870, (8) 2370, (9) 3010, (10) 3740, (11) 4750, (12) 6040, (13) 7500, (14) 9530, (15) 11800. These resistance values are in OHM's. Since you still have one of the keys, the parts department at your local dealership can tell you the resistance value of the key usually at no charge. However the key is no good without the VATS control module and the computer chip programmed to recognize it. No, the computer module and chip from the 91z are not compatible with the '87LT.
The Trickster!!!!!!!!!!!!!!!!!!!
Old Sep 29, 2003 | 11:09 PM
I EAT T/A's Avatar
Car: '87 Camaro
Yep, I have the entire electrical system from my '91 in my '87. Thanks for your help.
Old Sep 29, 2003 | 11:10 PM
I EAT T/A's Avatar
Car: '87 Camaro
You lost me on that one man, I'll just take my lucky car and run away now.
Old Sep 30, 2003 | 10:03 AM
Blue1989RS's Avatar
Car: 1989 RS
:rockon:
djmarch
May 8, 2016 11:32 AM
1992Z28!
Nov 19, 2015 07:33 AM
AmorgetRS
Sep 28, 2015 09:33 PM
bbsr72
Sep 27, 2015 05:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
