HELP!!! wiring question
Old Oct 11, 2003 | 10:33 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
ok, i have a brand new harness. and i just want the car to go. i dont really care about ins and outs, i just want the core basics that are required for allowing the car to run. i have a non-cc carb setup. obviously i need the battery, the alternator, the starter, and the distributor. is there anything else im missing?
Old Oct 12, 2003 | 10:41 PM
onebinky's Avatar
If you're not using the ECM at all, you are going to have to wire up all your gauges to bypass the ECM, and you will have to wire up your fuel pump also. It passes through a circuit that will not allow the fuel pump relay to activate if the ECM doesn't see oil pressure. I'm sure there is more, maybe the other guys on here can chime in to help you out
Matt
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
