Headlight problem
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Headlight problem
I have a problem with one of my headlights. When I turn the headlights on only the left headlight will light up. When I turn hte highbeams all the lights will turn on. Why is that? I would think if the headlight is burnt out that it would not work neither way. Any ideas?
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
There are two seperate filaments in the outer Hi/Low bulb. The inner Hi-only just has one.
You need to replace the headlight.
Pete
Pete
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
found this on a serch! damn from 3 years ago too {lol}
Anwserd my question? too!
Car: 83 Z-28
Engine: LG4
lol glad my problem could be of use to you
Its kinda weird you had the same problem around the same time of the year too.
Its kinda weird you had the same problem around the same time of the year too. Thread
Ghettobird52
Jul 5, 2024 11:18 PM
