Vss selection
Old Oct 18, 2005 | 05:24 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Vss selection
hey guys i swapped a t-5 into my 87 350 bird, and i need to figure out what part number etc of the vss for my bird, i know the ones from v6 t-5s will work but when i went to autozone they had 3 diff kinds, i assuming because of the diff mph speedos
i have a 140 mph speedo(electric)but the trans has a mechanical cable set up, i wanna switch it out to get my speedo to work probperly, and need to get the right plug to, i have the purple yellow etc wires hanging down,
thanks for any imput, lemme know if u need more info
Old Oct 21, 2005 | 02:39 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I am in the same boat too and would like to know how to get my speedo working with my cable drive on the t5.
Old Oct 21, 2005 | 08:55 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
as far as i can tel the only way that can happen is a custom mounted mech speedo, but remeber the vss also tell shte ecm certain things so basicly u need to have one to have ur engine run correctly
i spose i could buy one see if it fits if not then buy the next one in exchage for the one that doesnt fit
Old Oct 21, 2005 | 09:28 PM
Chevmdnss's Avatar
Car: 91 Caprice Wagon
Transmission: soon to be T56
Doesn't Dakota Digital have some sending units for this??? I think we went through this on the Impala board a while back.....When guys were swapping in TH400
Old Oct 21, 2005 | 10:54 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Not sure lemme check it out
Old Oct 22, 2005 | 11:24 AM
Chevmdnss's Avatar
Nevermind........ I found the site I was thinking about....
Speedo fixes
Start about halfway down.....
You'll love this site!
Old Oct 22, 2005 | 07:23 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
it has the 700r4 down here but not the t-5, Am i just blind or? lol
im trying to find a speed sensor to fit into my cable driven t5 ( or) an adapter that would go betweent he cable and the electronic speedo wires to make it work correctly
Old Oct 23, 2005 | 09:00 PM
Chevmdnss's Avatar
What T5 are you using???
Tremec, or Borg-Warner
Old Oct 24, 2005 | 10:08 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
As far as i can figure its the borg warner, i bought it from the guy who swapped it and he did all the mechanical stuff im kinda just tieing things up, i know its not brand new im guessing its a rebuilt borg warner t-5, hope this helps thanks
Old Oct 25, 2005 | 07:09 PM
Chevmdnss's Avatar
Read this info........
Pages 4 & 5 seem to be able to help
Old Oct 25, 2005 | 10:14 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
thanks seems to help im gonna try to swap one in
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
