instrument cluster died...help
Old Oct 16, 2003 | 06:44 AM
mrzippi's Avatar
the instrument cluster in my '90 iroc died on the way home yesterday.....nuffin works, not even the odometer, the tach, the speedo, temp, volt meter, nuffin. i was traveling at about 80 on some of theses "great" interstate hiways here in ms when i hit a swag in the road, the cruise was set, and i think the rear tires got a lil airborn. the "swag" wasnt a harsh/rough/shocking kinda bump just moderate. anyway everything on the cluster died. any ideas, i havent had the chance to check it out yet hope some of you experts could lead me in the right direction! thanks in advance!
Old Oct 17, 2003 | 01:54 PM
89BlueIROCZ28's Avatar
my cluster quit working after a speedo cable swap. turns out it wasn't seated completely. make sure its seated good in the back where the eclectrical contacts are. hope this helps.
Old Oct 18, 2003 | 02:21 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check the fuses, maybe?
Old Oct 19, 2003 | 06:02 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Check fuses, and take it out if that dont work and inspect the back side of it, make sure there are no broken connections in the green film board thing(dont know actuall term ) Make sure its got good connections into the two plugs comming from the dash that plug into the back of it.
Old Oct 19, 2003 | 07:53 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That circuit thing is called a printed circuit dash overlay if you happen to need one...
Old Oct 24, 2003 | 06:42 PM
mrzippi's Avatar
thanks
sorry ive been busy and havent had time to post up. it was the 10 amp fuse that blew, i replaced it and havent had anymore problems, just dont know why it blew in the first palce? thanks to all that gave me advice!
SS-EXPRESS
Sep 28, 2015 09:14 AM
James Sutton
Sep 23, 2015 02:18 PM
James Sutton
Sep 23, 2015 01:56 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
