P.N. for relay on 82-84 T/A's that works the hood scoop flapper
Old Oct 18, 2003 | 10:04 PM
TBI89Formula's Avatar
I just got the ram-air piece for my TBI formula (with the same hood as 82-84 t/a's). The piece came with the whole unit which bolts to the hood, plus the sylinoid. The sylinoid has a ground and a orange wire with a black stripe coming off of it. I was looking at a wiring diagram and it appears there is a RELAY which the orange wire plugs into. This relay has 3 other wires coming out of it, 1 goes to ecm...etc. What I want to know is the p.n. for the relay so I can get this ram air door working properly. Thanks
Ben
Old Oct 19, 2003 | 09:41 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
just connect it to a relay to remain on with ACC.
or just rig it to any vaccum controled relay to open at part throttle or full throttle.
be sure to remove the air silencer if your air cleaner has one (stainless mesh screens)
Old Oct 20, 2003 | 10:44 AM
What relays do I have on my '89 TBI Formula that are vac controled. I tried to find some in the wiring diagram, but had no luck. Thanks, Ben
Old Oct 22, 2003 | 12:53 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
I wouldn't set it up so that relay is activated all the time. They burn out too easy. A vacuum switch for full out throttle would be OK. Not sure where to get one though. I just have my solenoid hooked to a switch inside to activate at will.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
bryan623
Aug 10, 2015 11:33 AM
