brake-light problem
Old Oct 20, 2003 | 06:16 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
brake-light problem
Hey, I'd appreciate some input on this one. My left/rear brake light doesnt come on when my lights are off, but if i turn them on(parking or regular lights), it works. Kind of wierd... I don't know if this is related, but my left front highbeam is burnt out. Any suggestions?
Old Oct 20, 2003 | 07:21 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
probably just replace the high-beam light..as for the back,im not sure
Old Oct 20, 2003 | 07:31 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
did you try the bulb? could be shorted internal not yet burned out all the way and the filiment is touching inside and completeing circuit when running lights are on.
Old Oct 21, 2003 | 09:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
it sounds like you've got a bad ground. I've had similar issues with parking lamps and directionals. One side works with the lights off, the other side works with them on. 99% of the time, quirky crap like that is a grounding issue.
Old Nov 5, 2003 | 05:20 PM
Dirtbik3r's Avatar
sorry, I've been busy lately, I know some time has passed. Its not the brake light bulb, i think its a ground. Any clue of which grounds I should check???
Old Nov 6, 2003 | 09:14 AM
Jim85IROC's Avatar
The one that is broken.
i.e. start checking all the grounds associated with that circuit. Start at the source and work your way back.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
