push button starting
Old Oct 21, 2003 | 03:15 PM
chevcd2002's Avatar
Question is I would like to convert my 89 camaro to push button starting. Can anyone tell me what is involved in doing this and where I can get the parts needed to get this done? Also, how would you shut the engine off with the push button starter setup.
Old Oct 21, 2003 | 06:17 PM
DJsyclone's Avatar
I don't think you can do this because of VATS. Might try a remote starting kit from Sears though.
Old Oct 22, 2003 | 09:09 AM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
would you mind putting your key in and turning it to on .. then using a button to start it ? cause i can route you that way..
Old Oct 22, 2003 | 01:45 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
VATS not withstanding, you just need a switch to turn on the ignition, then a push button to connect the starter wires. All of the wires are in the harness that goes to the steering column.
Old Oct 23, 2003 | 08:08 PM
camaro of solar's Avatar
i would like to do this as well...and no i donnot mind putting the key in as well....how would I go about doing this??? I am mainly wanting to do it as an extra SURPRISE to somone who might try to nab my car....first they will have VATS on their *** and 2nd they wont beable to find the push button to start it...not like a theif would think abotu that anyways, unless they knew the car...
thanks...
Old Oct 28, 2003 | 10:39 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
cut the starter wire. i think its yellow under the dash. then connect the end that doesn't go up to the column to the push button, and the other to a switched 12 volt source. or to a constant if u always want to be able to crank it without the ignition.
Orr89RocZ
Apr 25, 2016 08:28 AM
The_Phoenix
Feb 4, 2016 07:10 AM
smooth
Aug 18, 2015 06:34 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
