air fuel gauge connection
Old Oct 24, 2003 | 04:33 AM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
I just bought a auotmeter cobalt air fuel gauge. where should i hook up the information wire directly to the o2 sencor? thanks
Old Oct 24, 2003 | 10:14 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Yes, splice it right into the o2 wire.
Old Oct 25, 2003 | 02:34 AM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
o2 sensor is on drivers side header right ? just making sure.
Old Oct 25, 2003 | 07:31 AM
Car: 1971 Camaro
Engine: 427
Yep
Old Oct 25, 2003 | 08:54 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
You can do that but that means you must go through the firewall. I spliced mine to the wire at the ECM. This way all connections are in the car and no splicing in the engine compartment. On both your cars the wire from the O2 sensor will be the purple wire(412), pin D7 on the 32 pin connector (the big one).
IMO, this will give you the cleanest install.
-Ozzy
Old Oct 25, 2003 | 10:17 PM
Car: 1971 Camaro
Engine: 427
Sweet idea!
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
86Base
Aug 13, 2015 05:06 PM
