Possible computer problem
Old Oct 30, 2003 | 06:55 AM
Thirdgen86TA's Avatar
Last night by check engine light went on and it idled kind of funny. It wasn't real bad just a little higher. I have an aftermarket custom burnt chip also. Well I tried to pull a code with the paper clip and the light wouldn't flash. Then I used my scanner to get info out of the computer and it keeps saying NO DATA. Also the fan is always on when I have the key in the ON position. I am assuming this might have something to do with the computer or chip. I don't know much about electronics so if someone could give me ideas I would appreciate it.
Old Oct 31, 2003 | 01:31 AM
Morley's Avatar
Fans on with the key on is limp home mode, worst case is a bad computer or chip. Could also just be the chip isn't seated in the ECM fully or the connectors to the ECM came a little loose. Check those 2 first.
Old Oct 31, 2003 | 02:27 PM
I put the stock chip back in and it ran ok for a few minutes and then started doing the same thing.
z28addict8490
Sep 5, 2015 03:56 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
perZ
Aug 15, 2015 01:17 PM
