No power at injectors
Old Nov 10, 2003 | 12:36 AM
NO2TransAM2002's Avatar
Car: 85 Trans am
Engine: 5.7
I have an 85 Trans am TPI. It wont start becase the injectors wont give it fuel. I checked fuses and they are fine. AT the injector plugs I checked with a volt meter while trying to start and all 8 have absolutly no voltage. ECM gives me a normal operation code and I have a new ignition module, what else could it be? Thanks
Old Nov 10, 2003 | 09:15 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
my first guess on this one would have to be VATS (vehicle anti theft system) which if the correct key isnt used, will not allow power to the injectors
Old Nov 10, 2003 | 10:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
VATS came out in later Years. Is your fuel pump working, have you checked to see if you are getting fuel pressure at the rails.
PS: I'm not sure if you would get a voltage reading from the injector connectors since they pulse rather quickly and do not hold a steady reading. .
The Tricskter!!!!!!!!!!!!!
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
mdtoren
Aug 16, 2015 05:45 PM
