92 Camaro Power Window Switch Installation
Old Nov 11, 2003 | 06:18 PM
fb1907's Avatar
Hi, I just got a camaro 92 RS.... I have the power window switchs but I have to wire them.. can someone tell me where I can find the color codes? thanks
Old Nov 11, 2003 | 07:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, I can. Give me a few minutes and I will e-mail it to you if you have an e-mail account in your profile.
The Trickster!!!!!!!!!!!!
Old Nov 11, 2003 | 07:05 PM
fb1907's Avatar
thanks trickster..
You can use the same e-mail address in my profile...
themedit1979@yahoo.com
Old Nov 11, 2003 | 08:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Fbod1907,
You have e-mail!!!!!!!!!!
The Trickster!!!!!!!!!!!!!
Old Nov 11, 2003 | 08:03 PM
fb1907's Avatar
Thanks a lot trickster I really appreciate it.. Now I have to figure out what the diagram means
Old Nov 11, 2003 | 08:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
are you referring to the color abbreviations or how the wiring is run?
Old Nov 11, 2003 | 08:10 PM
fb1907's Avatar
the color ones.. I saw that there are like 5 different cables and they are 2 sets.. I just have to plug them into the switch.....
Old Nov 11, 2003 | 08:33 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Ok,
Look at the connectors for the switches and you will see letters on them. Left hand switch: Pin "A" is brown & goes to Pin "A" of motor(down side) , Pin "B" is black (ground), Pin "C" is dark blue & goes to Pin "B" of motor (up side) and Pin "D" is pink & goes to fuse block (power). Right hand switch: Pin "A" is tan & goes to Pin "B" of motor (up side), Pin "B" is black (ground), Pin "C" is light blue & goes to Pin "A" of motor (up side, Pin "D" is pink & goes to fuse block(power) Hope this helps
Old Nov 11, 2003 | 08:41 PM
fb1907's Avatar
Thank you very much... I really appreciate your effort ..
I will try the settings tomorrow...
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
