Digital dash bulbs
Old Nov 14, 2003 | 02:12 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Digital dash bulbs
I did a search, couldn't really get the answers I need.
88 GTA with digital dash. Some of the digits do not light up. An "8" will look like a "0" because the middle bar doesn't light. A "7" will look like a "1". Things like that.
The question is, can this be repaired by replacing bulbs in the cluster. Do the bulbs help to backlight the guages to make the number visible or is each digit actually made of 7 little bulbs shaped like a square 8? Can this be fixed or do I need a new cluster?
Kevin
Old Nov 14, 2003 | 03:51 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
http://www.mrwhizard.com/index.cfm
a friend of mine used these guys, I don't know if they to TA's but you can contact them.
Old Nov 17, 2003 | 10:54 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
all of the numbers are part of the LCD display. The back-lighting is just the common 194 bulbs. If the whole section of the cluster goes dark, that's the 194s. For specific segments of hte display, you're basically SOL unless you replace the whole piece.
For what used dash clusters cost on ebay, I wouldn't bother getting yours repaired. Buy another cluster and replace the segments that need to be replaced.
sheachopper
Jul 31, 2019 11:27 AM
Lbibb
May 5, 2016 12:00 AM
86IROC112
Nov 7, 2015 06:50 AM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
