Choke light..help
Old Nov 15, 2003 | 11:17 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Choke light..help
Hey.
Since Ive had my car. Since about last february my choke light has constantly been on except for like a month ago it turned off for a week or two. But its back on. Someone I know said it could be something with the alternator? He said unhook the red cable while its running and itll tell alot..I did that. And the car still runs...Does that mean its not the alternator???Another friend of mine also checked the choke and he said its fine...Im gonna take my car to the shop next weekend to have it checked out.
Wondering if you guys have any ideas? Maybe I could find out how to just turn that damn light off. My car starts up fine. Im not really worried but Im selling it soon. So....
Nate
Old Nov 17, 2003 | 08:22 AM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Re: Choke light..help
Originally posted by ddn69
Hey.
Nate
It might be the electric choke relay, it's either stuck or fried. The relay has three wires coming from it;
Brown - Leading to the C-H fuse on the fusebox. Which splits, and leads to the battery (hot at all times)...
Red - To the alternator...
Light Blue - This wire splits into two, and one part leads to the electric choke, while the other turns from light blue, to pink/blue, and leads to the electric choke warning light indicator.....
Old Nov 17, 2003 | 08:55 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
hey. That C-H fuse on my panel is constantly burning. Maybe that tells me something?
Old Nov 17, 2003 | 08:58 AM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
What size fuse are you using? If it burns out, that means there's overload somewhere....
Old Nov 17, 2003 | 06:53 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Also not a good idea to pull off the red wire from the alt, the alt most times is damaged by haveing a voltage spike for a second or 2 it takes to realize the load was removed.
Old Nov 21, 2003 | 01:25 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
hey guys Im taking my car in on monday to have it checked out. Im having the choke, timing, and a spark plug looked at. Hopefully it shouldnt cost too much. The mechanic Im going to is a good guy.
When I went to speedy to get an estimate for plug wires and plugs+fuel pump they told me 400.00 LOL I put that thing in myself. And was no where near worth 400.00 to put in a few wires and a fuel pump. LOL
I would just ask a friend to help me out with the plug. But while Im getting the choke looked at I mine as well get the plug done too. Im thinking its fried cuz the wire fried on the manifold a bit ago. Im also getting weird idle speed...Like not even wanting to stay started when I first start it up when its cold and not wanting to go under 1500 or 1200 when its warm even. I used to idle pretty low when I was running right....
Old Apr 18, 2010 | 07:09 PM
lo-z's Avatar
Car: 98 Chevrolet S10
So, where exactly is this Choke Relay located? My altinator, battery and all my fuses are fine. I have been going all through these posts and still can't seem to get my choke to work or the light to go away. It started after I installed headers.
Old Apr 18, 2010 | 07:23 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
The choke relay is on the right fender by the battery.
Old Apr 20, 2010 | 12:19 PM
crazyeight's Avatar
Car: Pontiac Firebird 1987
Engine: 305 4bbl
Try with some electronic cleaning spray. I sprayed my relay with it and cleaned it and now my choke warning symbol is gone.
Excuse my bad english
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
