headlight problem
Old Nov 26, 2003 | 01:47 PM
91Z28-350's Avatar
headlight problem
Hi all,
I'm upgrading the wiring for my headlights, as stated in the tech articles section. I'm hitting a strange problem though. The wiring and relays are all good, except I'm getting some voltage leaking through the low-beams headlights. It's strange. I tested the wiring and it's all good. The leakage seems to be coming from the Sylvania XtraVisions that I have.
With my stock harness, the voltage diff across the low beam headlights are 9.9V. With the new harness it's 11.8V. However, with the higher voltage, there's leakage of voltage onto the high-beam wire and it turns my high-beams on. I can't seem to understand it. Is there some diode on the headlights that are being oversaturated?
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
