Car died while driving? S.O.S!!!
Old Nov 26, 2003 | 08:58 PM
E-man007's Avatar
While driving to work this morning I hit a pothole preety bad and the bump made my car turn off. I steered the vehicle off the street and tried to turn it on again but nothing happened. None of the lights on the dash came on(security light,air bag,SES)so I turned the lights on to see if they would come on and they worked w/o hesitation. With the ignition switch open I went to the engine and started fiddling with the battery,alt, and the plugs that go to the coil,still nothing. Then the lights on the dash came on out of nowhere and the car turned on with no problem.
Like two days before the car turned off on me, the wires that plug into the coil were exposed and were making contact with my open air element. I bought a new plug and fixed this problem. Ever since my car turned off, I feel my ignition switch a little more difficult to turn when I turn on the car. Im putting all these things out to make it easier for those that might have an idea to help me diagnose the problem. Any ideas what it could be?
Old Nov 27, 2003 | 05:41 PM
Morley's Avatar
Loose ground, check the ground wires at the back of both heads and on the firewall.
Old Nov 29, 2003 | 01:07 AM
bytal's Avatar
Car: 88 Pontiac GTA
Engine: 5.0L
Transmission: Manual
similar thing happened to me shortly after i got my car.... sill learning stick at the time.. stalled it at a stop sign... wouldnt start up.. got her pushed over to the side.. buddy came down to look at it... ignition coil wire...
Old Dec 7, 2003 | 03:54 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
does it crank? maybe one of the wires on the starter was loose.
Old Dec 9, 2003 | 05:42 AM
crazy8s's Avatar
Car: 1988 IROCZ
Engine: L98... for NOW
Transmission: Corvette
ignition control module under the dist cap... if you have tpi (or others, i dont know what cars have this). this happened to me.. had me stumped for 2 months. it would just turn off sometimes, and start randomly.
wheres huntington park... ill come down and look at it for you.
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
