Red Power wire for heater controls burnt?!?!?
Old Nov 28, 2003 | 03:09 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Ok guys heres my prob. My heater and blower and everything appears to function just fine. But the Red wire that supplies power to the controls (Red wire w/grey connector coming out of harness near the coil) has melted the connector completely off!!! What is causing this one wire to get so hot???
Old Nov 29, 2003 | 08:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you say the wire is getting hot, could you be a little more specific. Is the wire getting hot while power is applied, or the engine running. Can you feel the wire getting hot by touching it or are you just going by the fact that the connector is melted? Is it hanging close to something that gets hot when the hood is closed?
BTW, as I mentioned in another post you had on this subject, there are two areas these red wire go to. One is the AC/heater blower motor control and the other one is for the under hood light.
The Trickster!!!!!!!!!!!!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
