rapid fire adjustable switch
Old Dec 10, 2003 | 10:45 AM
xaivior's Avatar
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
OK this has nothing to do with a car but this is the only place I know of I can get help ..so here goes
I need to wire up a switch that will turn itself on and off at a rapid rate the switch will carry 24Vac but I need to make the switch adustable to speed up or slow down
the way its setup is it plugs into 120v wall outlet into a transformer with 24v secondary through the switch and to an output like a male connector
If anyone can help me with this I would GREATLY apreciate it
Old Dec 10, 2003 | 11:12 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
first tell us what you're trying to do, and we may be able to give you a better solution.. heh.
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 21, 2015 07:20 PM
dcbsracing007
Aug 18, 2015 07:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
