alt problem....
Old Dec 11, 2003 | 05:49 PM
StealthElephant's Avatar
Car: 87' Iroc
alt problem....
For some reason my alt isn't charging my battery. Now...it's wired correctly in the engine bay, but I'm thinking maybe somewhere in the fuse box a wire isn't right (we did some reworking). Did a brown wire going to the fuse box have anything to do with it?
Right now what I'm thinking is that some sort of relay/sensor made sure that the alt didn't overcharge the battery, and that if I cut that wire it doesn't charge as a safety precaution.
Any ideas? Cause I know the alt is good, but we messed with the wiring, and now its working. In actuality, I was not present when the wiring was redone. It's a 1 wire alt, it shouldn't be too complicated.
Old Dec 11, 2003 | 06:01 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Here's a site with any and all wiring diagrams you will need when you go to tackle this problem:
http://92b4crs.tripod.com/86wiring/86wiringindex.html
Old Dec 11, 2003 | 06:10 PM
Car: 87' Iroc
thanks
Old Dec 11, 2003 | 07:38 PM
Car: 87' Iroc
Ok, maybe I'm just retarded (which I would believe), but the website has links for VIN F, VIN H, and VIN G. Now my car is a V8 car so it's one of those 3, which digit of my vin is that for? Cause my vin has 2 Fs, 1 G, and 1 H.....heh....
Old Dec 11, 2003 | 10:44 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The eighth digit of the VIN on your car is the engine digit: Mine is "S", meaning I have an LB8 MFI V6:
xxxxxxxSxxxxxxxxx in this example.
BDR
Nov 7, 2015 03:05 PM
J.C. Denton
Sep 21, 2015 04:23 PM
Slush92RS
Sep 2, 2015 08:56 PM
firestorm
Oct 2, 2000 09:57 AM
Mkos1980
Sep 20, 2000 10:00 PM
