reverse lites
Old Dec 12, 2003 | 10:07 PM
C3VET4ME's Avatar
Car: Corvette
reverse lites
I installed a T-5 in a camaro that originally cam witha 700r4 so now i have no reverse lites. My question is-is there anyway to wire in a manuel switch to turn them on? like a toggle switch or something? so i could just turn it on instead of rycing out the car with a backup wide load coming threw beeper.
Old Dec 12, 2003 | 10:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It would be just as easy to just wire the reverse switch in the transmission.
Old Dec 13, 2003 | 08:04 AM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
just take the wires that did run to your shifter in the automatic and run them down to the reverse switch on the transmission. Did you hook up the neutral safety switch?
Old Dec 14, 2003 | 01:47 PM
Z28GEN3's Avatar
Old Dec 14, 2003 | 01:56 PM
C3VET4ME's Avatar
Car: Corvette
I dont have a neutral safety switch. The only thing i have on my harness is the Auto trans switch. which i have locked in the park position so i can start it and drive it. the interior harness is designed for the 700r4 trans as is the computer. the only other connection on my trans is a flat 2pin female connector with a brass like nut against the trans body. and the harness for the engine is also for the AT.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
84redta
Sep 19, 2015 09:58 AM
