LG4 wiring harness help
Old Dec 14, 2003 | 11:16 AM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
So in the middle of my engine transplant i decide i want both of my windows up, but i have power windows and they're both down right now. how would i go about getting them up? i took all the wiring harness out of my car for now but it's still good and intact. i noticed that there is two harnesses coming out of the drivers side firewall. the one smaller one is for the front end lights and stuff, but what is the other (bigger one) for? do i need it if im not going to be running a computer? all this wiring confuses me!!! thanks for any help!!
Conner
Old Dec 14, 2003 | 01:52 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You need both of them. One runs the lights, like you mentioned, and the other goes to the engine accessories - starter, alternator, choke; and also contains the feed lines from the battery to the fuse block.
You could use your battery and a pair of booster cables to put your windows up; clamp the negative side to a chassis ground (crossmember or something) and hook the positive to one of the thick red wires near the starter connection. Then try your headlights - if they come on, switch the positive connection to the other red wire. Then turn your key forward to the 'RUN' position, and hit the window switch.
Pete
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
