help with volt meter
Old Dec 14, 2003 | 07:41 PM
camaro_91's Avatar
Car: 91 Camaro RS
Engine: just put in 305 building a 406 ci
Transmission: 700 R-4
i made a costem gauge cluster for my 91 camaro rs and i dont know how to hook up the volt meter dose any one know how...
any help will be appreciated....
Thanks.....
Old Dec 20, 2003 | 03:54 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Just hook up the power source for the meter to any 12 volt hot when the engine is running source. I spliced mine into the stock harness, using the factory wire for the factory volt gauge to power my Autometer.
Another option is to use the terminal specifically for this purpose on the back of the alternator.
Old Dec 20, 2003 | 04:56 PM
camaro_91's Avatar
Car: 91 Camaro RS
thanks, TKOPerformance
i going to go try it right now
i have the older alt. so there is only two wires red and white
can i hook it up to the white wire to get a reading if it dose not work ?
thanks....
Old Dec 20, 2003 | 06:34 PM
You'd be better off connecting to the 12 volt keyed plug in the fuse box. Then you don't need to run the wire through the engine compartment.
The old style 12SI and 10SI alsternators have a red wire and brown (sometimes white or other colors) wire that control the stator and the rectifier respectively. The white wire should be a reference signal to the rectifier assembly, so you wouldn't want to tap something off of this wire that will produce a current draw, even if it is a relatively small one. The result could be overcharging the system and burning up the alternator.
Use the 12 volt keyed tap. You can use a spade connector to plug into it, or they often sell a pigtail for it at parts stores. There are at least two taps, and one is 12 volt constant. Use a test light if you are unsure. Plugging in to the 12 volt constant will result in eroneous readings.
Old Dec 20, 2003 | 06:40 PM
camaro_91's Avatar
Car: 91 Camaro RS
thanks i got it i hooked up one to a hot 12 votl while it was on and the other one to a good ground dan it works
thanks for all the help, TKOPerformance
Old Dec 20, 2003 | 07:01 PM
No problem, good luck with it!
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
