Courtesy Lights
Old Dec 15, 2003 | 05:09 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Courtesy Lights
My car has no courtesy lights, and I was told that they were pretty much standard. So I started diggin around beause it may be there with no bulb or burnt or something. But diggin around I found these:
Passenger
Driver
The orange and white in that pic, could that be it? I have more pics of wehre that goes, it turns into white wires and just goes up into the dash i cant tell wehre, and then the other side turns into a fat black wire that just goes under the carpet to the rear....
What else could that be?
Thanks :lala:
Old Dec 16, 2003 | 08:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
thats suppost to be it.
if you had that option, the wires end in a 1/4 turn light socket thats connected to the underdash cover panel.
my 82 camaro had them.... my 91 camaro vert only has the lights on the underside of the mirror.
Old Dec 16, 2003 | 03:39 PM
Car: 95 Z28
By that do you mean the hush panel? My wires are just exposed, I nver had the panel... By that do you mean the red purple and yellow green or the white orange plug thing? I really want em and I dont see anything to the effect of a 1/4 turn light
Old Dec 17, 2003 | 11:46 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
White/Orange should be the only interior lighting wires. I think the others are either ECM related or maybe for the radio
Will
Old Dec 17, 2003 | 11:50 PM
Car: 95 Z28
Any Idea Which is + and -? lol
Old Dec 18, 2003 | 12:01 AM
norcalz28's Avatar
I hate reading wiring diagrams, but I wanted to make sure. Looks like orange is pos and white is neg. Hope that helps
Will
Old Dec 18, 2003 | 12:04 AM
Car: 95 Z28
that does so is orange the switched one with the door?
How do I put a light on that, lol
Old Dec 18, 2003 | 12:11 AM
norcalz28's Avatar
Your best bet would be to go toa junk yard and pull the little connectors out of a wrecked car or something. Cut em off with enough wire so that you can just crimp em to your existing wire. And you should be golden. The connectors will fit a 194 bulb
Will
Old Dec 18, 2003 | 08:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Will
not to mention, you'll see the colors the wires are and such.
im pretty sure thoes yellow and green ones are the pass side footwell light.... however thats off of memory.
i dont have them in my 91 or id just look and tell you.
Old Dec 18, 2003 | 12:43 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
the orange wire is a constant 12 volts, if u have ever taken down your dome light, there is also a orange and white wire going to it too, the white wires are connected to the door switches, which when either door is opened, supplies ground to the white wire, turning on the interior lights
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
