Push power window switch....car goes dead??
Old Dec 22, 2003 | 01:08 PM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
Ok today when I got in my car I went to put the drivers side window down and when I push the switch it causes a big power drain or surge that shuts the car off. The window doesnt move and the battery gague and rpms surge down when I hit the switch. If I do it when the car is just at idle then the car just shuts off.
I dont really know what it is. I have had a window motor break before but that just made the window slow down to a stop. This is different. There is such a power drain when I hit the switch I dont know if the switch is fried or if there is a short in the window motor?
Please help me....I live in Tampa and its warm down here
Old Dec 23, 2003 | 08:41 AM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
Also when I push the button up nothing happens, its only when I try to push it down.
Someone has to have some ideas. I need to get this fixed asap.
Old Dec 23, 2003 | 12:02 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
start checking stuff i dunno. get a wiring diagram, check the switch, motor, etc. make sure the window gear isnt binding. check your grounds and fusible links as well while your at it.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
