Headlight problem
Old Dec 19, 2003 | 03:17 PM
wolfe's Avatar
Car: !986 firebird
Engine: 2.8 v-6 (pure power)
Transmission: stock
Headlight problem
HI, im puttin a camaro fron end on my firebird, and i was wonderin if any body knows:
Are the wire colors different?
if so does anyone have the diagrams for both the firebrid and the camaro?
any help would be appreciated.
Old Dec 19, 2003 | 03:44 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
"shakes head in disbelief"!
Don't know....but I wouldn't do it!
Old Dec 19, 2003 | 05:04 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It will work, as long as you wire in a second connector for the inboard high beams.
An easier way to go would be to get the complete underhood headlight wiring harness from a Camaro and swap in; they unbolt at the firewall next to the brake booster.
Pete
Old Dec 19, 2003 | 05:14 PM
Car: '89 Formula
Engine: 305 TBI
OK.......I've been as good as I can be....
...I've got to ask.
WHY would you be putting a Camaro front end on a Firebird?
My curiosity is killing me!
Old Dec 20, 2003 | 02:17 AM
Morley's Avatar
Don't forget to change the fenders too.
Old Dec 20, 2003 | 03:22 AM
wolfe's Avatar
Car: !986 firebird
Transmission: stock
Im puttin the camaro front end on because, i crashed the firebird up, and having an extra camaro around for parts(Bought it for the engine) just seemed to be the answer, plus i just got this urge to see how it works. And i did get a new set of fenders(dented them up too)
Old Dec 23, 2003 | 01:19 PM
wolfe's Avatar
Car: !986 firebird
Transmission: stock
Ive been studying the wiring diagrams for the firebird and the camaro ,and must admit, im confused. Could anyone please help and make this make sense?
Wolfe
Old Dec 23, 2003 | 01:33 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The 'bird headlamp plug will work on the outer camaro lamp (low beams). You just have to tie/splice another harness plug into the green wire for the inner high beam lamp that the camaro's have. Take the camaro high beam lamp and plug w/wires, splice green into green and ground the black.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
