Turn signal ? after tightening steering column.
Old Dec 29, 2003 | 12:35 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Ok guys, I tightened up my column like in the tech article, and when I put everything back together, I pinched the wire that goes to the turn signal lever in the bracket that holds the steering column up. Needless to say it was blowing my gauges fuse, well I got the wires outta there and now am getting a new turn signal lever. I have rear turn signals, but not fronts now, and my indicator for the turn signals on the dash doesn't blinker or come on either. The highbeam indicator works, just not the signals. What is the cause of this?Will the new signal lever fix this?
Old Dec 30, 2003 | 10:14 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Sounds like you damaged some wires when you over tightened. Most likely the ones for your front signals. Go in and inspec the wires closely. Also check your connection on the column. The long connector right about knee level. Those can be connected backwards. make sure it is correct.
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
