Major Wiring Problems
Old Dec 22, 2003 | 11:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Converted my GF 91 3.1 V6 SD to a 89 350 TPI MAF. First problem I find is that there is no connector to attach the sensor to the sensor right under the brake fluid container. Second of all. When I plug the two clear connectors to the two main black ones under the dash the bigger of the two is fine but as soon as i plug in the smaller one the ACC fuse blows. I also can get my scanner to read the MAF computer through the dia port. Also cant ground it out so the fans kick on. I'm at a lost .
Old Dec 30, 2003 | 10:19 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Does your computer have 3 connectors or 2?
Old Dec 30, 2003 | 10:22 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
2 into the back of the ecm and two black ones which connect into 2 clear connectors under the dash. When the little one (1/4 shorter) of the 2 black ones to the clear ones are pluged in the acc fuse flows and stuff.
Old Dec 30, 2003 | 10:23 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
1989 has 2 connectors on the computer. 1990 started using 3 connectors. I converted the wiring from an '89 to that of a '90-'92. If your trying to hookup an '89 motor to your '91 computer then your in for a big surprize. Your going to have to delete a few things and add a few things.
Old Dec 30, 2003 | 10:25 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Were using an 89 ecm and harness, but when the other wires are connected to the lines in the dash tats when the problems start. ign works fuel pump works wipers . Bascialy everything, but the acc fuse blows. and gas guage doesnt work
Old Dec 30, 2003 | 10:31 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
your going to need a different wiring harness or help with the one you have. The clear harness you refer to is just a juntion. Who told you the sensors would hookup to your existing computer? You have a bunch of work ahead of you. Howel electronics does specialty wiring for all cars. They have adds in most chevy magazines in the back of the mag. or painless wiring sells a harness for about $200. or a little less.
Old Dec 30, 2003 | 10:35 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
the computer, harness and sensors are all from the same car (89 Formula 350. I'm tring to understand. Everything works but I blow the acc fuse like a short,
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
hokis
Aug 9, 2015 03:57 PM
