blower motor
Old Jan 4, 2004 | 05:55 PM
beenwiggin's Avatar
blower motor
Need wiring help 101. Blower motor quit working took out blew it clean and wired direct to see if working,it does but when putting it back in it quits. When touching the blower to the accumulator it blows. being ignorant what the heck can I do to fix it.Thanks
Old Jan 4, 2004 | 07:51 PM
Slick86's Avatar
Car: Pontica F-bird
Engine: 355
Transmission: 700-R4
its either the relay or follow the harness back. i found the ground wire can come inhooked really easy. Its not along the harness. its a separate wire
Old Jan 8, 2004 | 07:46 PM
beenwiggin's Avatar
Thanks Iwill try to find the ground wire before buying a relay
Old Jan 12, 2004 | 10:50 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Bridge the realy socket and see if the blower works. If it does you've found the problem (relay) if not start tracing wires.
Old Jan 31, 2004 | 11:50 AM
davis's Avatar
Car: 85 Sport Coupe, Z28
Engine: 350 4-bolt main
i got a problem like this to
i was going down the road and it just stop workin look at the wires and i cant find anything wrong with it how do i check the relay and what dose it look like u said that u check it ty
Old Jan 31, 2004 | 04:20 PM
3gc's Avatar
3gc
Car: Z28
Since when you touch it to the acumulator it works it definately sounds like a ground problem. Trace the ground wire which is the black one connected to the blower and see if it's connected. I think it's connected to the heater box stud behind the passanger side valve cover.
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
