Painless Wiring?
Old Jan 7, 2004 | 09:57 AM
AFTERMIDNIGHT's Avatar
Car: 1989 Camaro, 2008 600RR
Engine: 311
Transmission: T-10
Axle/Gears: 02 SS Rear with 3.23 Gears
Painless Wiring?
has anyone done a painless harness or something of the sort. i removed everywire in the car and i would love to put all new back in. i can get a painless kit for aroud $300. any input, good or bad, would be great. thanks guys Patrick
Old Jan 7, 2004 | 10:44 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Painless Wiring?
Did it, ended up removing it and installing a stock 91 chassis harness and modifying / blending the engine harness to work with my motor, hacked up that $300 harness from them for spare wire, cant beat the factory bulkhead connector etc when it comes down to it.
Old Jan 9, 2004 | 09:01 AM
Engine: 311
Transmission: T-10
sounds like a good way to go with the factory setup. thanks for the input, looks like i'll put the factory wires back in( took it all out without a single cut.(proud of that, too hehehe) thanks am
Old Jan 10, 2004 | 09:22 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
I installed a painless wire harness and have not had any problems with it. The harness is clearly marked for each wire with a tag. Harness is well made and is much easier that a stock harness from a used car. The wires from painless are excellant quality and is easy to install.
Old Jan 10, 2004 | 09:50 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Agreed, got a paniless TPI harness and had no problems with it at all.
Then about a year later got another painless harness (18 circuit GM) to go into an MGB, worked out great.
Old Jan 12, 2004 | 10:48 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The biggest problem with the factory harness is its age. I've seen a ton of electrical gremlins that resulted from nothing more that a bad connector or some chaffed wire. I'm not saying don't re-use the stock harness, though. If you do go through it carefully and inspect all the sockets and connectors. Replace anything that looks questionable. Waterless hand cleaner works great for removing grease and goo from wiring.
I have no doubt that the Painless harness is top quality. I've used several of their products, and have always been very happy with the quality.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Ducati900ss
Sep 2, 2015 09:05 AM
stalkier
Aug 21, 2015 01:54 AM
squiggy2
Aug 9, 2015 09:30 PM
