Fog light troubles
Old Jan 9, 2004 | 10:36 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Fog light troubles
Hey guys, I just got some factory fog lights off of a 91Z and they came with the plugins in the back of them. They have a little bit of wiring on both plugins and then they have been cut. How would I go about hooking these up? There are two wires coming off each of the plugins. Is one just a power source and the other a ground? What would probably be the easiest way to wire them up? Thanks in advance! Eric
Old Jan 10, 2004 | 12:24 AM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Yea, ones power, ones a ground. On my 85 TA purple is power. I''m not sure if the color is the same on yours though.
Matt
Old Jan 10, 2004 | 11:32 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Cool man thanks! So can I just splice the power into the driving light wires so when I turn on my lights the fogs come on? What would be a good way to hook these up?
Old Jan 10, 2004 | 01:51 PM
Matto'85TA's Avatar
You could do that. But the best thing to do is to put it to factory original wiring. Running the fogs directly of the parking lights could possibly overload the circuit.
Matt
Old Jan 10, 2004 | 02:20 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
How would I go about that? Is it possible to run it to another circuit so it doesn't overload it?
Old Jan 11, 2004 | 04:21 AM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
Go buy a cheap fog light kit and just dont use the lights included in the kit. Because the factory and aftermarket kits have a separate switch, inline fuse, relay, and 20 ft of wires etc. Install as the instructions say and you'll be cool.I went out and bought a kit just for the lights because both of mine were broken
Old Jan 11, 2004 | 03:37 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The cheapest way is to buy one relay and one switch and some wire.
Here in VA, when the car is inspected and has fog lights, aftermarket or stock, they need to turn off when the hi-beams are activated. If they do not turn off, then you fail inspection.
GTAman
Mar 15, 2019 11:40 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
mustangman65_79
Aug 12, 2015 06:39 AM
