brake lights still not working
Car: 1987 Z28 Camaro
Engine: 305 tpi
ok for awhile now, my break lights have not been working, they quit workin when i got my front ball joints replaced, i checked everything from the back and they still work, i looked at the brake thing under the brake, haha dont know what its called, and its just find, so im think its somewhere up front, where the problem is,, since it went out when the worked on it, so anyone know anything bout this, please help asap, 5th time i've been pulled over, 4 by the same cop
, Last edited by 87z28camaro; Jan 12, 2004 at 05:50 PM.
Car: 1985 Black IROC-Z
Engine: 305 T.P.I (for now)
Transmission: TH700"R"4 (R for Racing)
Check the fuse box, the brake bulbs, and brake switch on the brake pedal. Or have a friend press the brake pedal while you check a brake light (rear) with a power tester? I had almost the same problem, only mine was just a simple adjusment to the switch brake on the brake pedal. If nothing works than my friend take it to an electrician
laters
laters
When my brake lights stopped working I though I had checked everything.
did a search brake lights and got this posting.
Did everything but check the fuse. Sometimes it's the most basic/simple things.
Thanks Bandit-Z for the common sense.
Terrell351
Jun 13, 2021 01:13 PM
