idiot lights--->gauges, 82-84 bird
Old Jan 18, 2004 | 11:30 AM
my84firebird's Avatar
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
I recently aquired a gauge cluster from an 84 t/a which has the full gauges instead of just the speedo and gas gauge, which i currently have. When I tried to install it, it intantly popped the "gauges" fuse as soon as I turned the key, and obvoiusly none of the gauges worked. I tried it several different times and it just kept popping the fuse. Is there more involved in this swap? Or did I just get a bad gauge cluster?
Here's what I have now:
Old Jan 18, 2004 | 11:31 AM
Engine: modded 5.0
and here's what i want:
Old Jan 18, 2004 | 11:33 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Moving
Old Jan 20, 2004 | 01:39 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
Yes, there's more involved.
The pinouts on the connectors behind the dash gauges are not exactly the same from what I remember.
You'll need to pull the connectors out far enough from the dash behind the gauges so you can switch the pins (wires) around a bit. Therefore, you'll also need a shop manual to figure out which ones need to be switched.
I'm guessing you're popping the fuse because something is shorting out due to the wrong connections.
Also, I don't think your oil pressure and temp gauge aren't going to work because you don't have the right sensors, your dummy gauges use different ones. That would be a simple part store trip I imagine.
Old Jan 21, 2004 | 04:47 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
yeah the dummy cluster sensors are made so when they rich a certian temp or pressure they activate, it isnt a measurement like the real gauges are
87v6Bird
Jul 1, 2018 04:12 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Rally Smith
Sep 14, 2015 06:59 PM
Glowsock
Sep 6, 2015 06:40 AM
