Starting Problem
Old Jan 23, 2004 | 11:13 AM
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
Starting Problem
This is with my winter car, a '95 Monte Carlo Z34 with the 3.4L. Sometimes the car cranks as soon as the key is turned, other times there is a few second delay before it starts cranking and other times it won't crank at all but after sitting for a few minutes it will. Starter? VATS? Ignition Switch? ECM? Once it starts cranking the car starts right up and it cranks at a decent speed. Thanks
Old Jan 24, 2004 | 09:33 PM
CamaroRS1990Guy's Avatar
Car: 1990 Camaro RS
Engine: 305 soon to be 383
It probably not anything electrical, is your starter turning and your selinoid kicking out, if it is it probably not going to be your starter. does it have a carb or is it fuel injected? I would check your fuel pressure getting to your engine when your trying to start it.
Old Jan 26, 2004 | 05:42 AM
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
Turned out to be the Solenoid! All is good now. Thanks
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
