Custom aftermarket gauge set up, 91-92 Camaro>>
Old Jan 22, 2004 | 04:25 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
Okay, after swaping my TBI (POS) out for a carbed 388 stroker, I went ahead and ripped all the computer crap to go with it. No, as you would guess, I have NO gauges that work in the stock cluster. I am not worried about most of them, except the MPH and Fuel gauge. I have aftermarket temp, oil pres and RPM gauges, however, I am looking for guidance on setting up an aftermarket cluster (autometer stuff) for the direct replacment of the 91-92 stock cluster.
My questions are these:
1) Does any aftermarket company make this? (I do not think so)
2) For those whom have done it, can you post pics, and explain where you hooked your wiring to and what you made your cluster with (i.e plastic, but from where?)?
3) With the 700R4, is there an aftermarket MPH gauge that will work the the eletc transmission?
Thanks, I just need to figure this out so I can tell how fast I am going..
-GOFASTER-
Old Jan 22, 2004 | 10:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i used a piece of sheet metal that i bought from a local home depot kind of store.....in hindsight i'd go with aluminum since you can polish it up really nice and it'll be easier to cut through. but that's my two tips.
Old Jan 23, 2004 | 03:30 PM
David Petersen's Avatar
This isnt' the cheapest way to go, but you can get it in a variety of finaishes and diffecrnt guage styles or use your own guages.
When I started adding up just the gauages alone the price doesn't seem as bad. Summit and Jegs now sells them.
Here is the site
http://www.covansclassic.com/parts/i...60612.24.61.12
Old Jan 23, 2004 | 05:23 PM
xpndbl3's Avatar
Car: 1984 Z28
well to put it into perspective....that plate is $120 plus shipping.....i think i spent $6 on the sheet of metal and "maybe" 1.5 hours on the whole thing. So i guess technically i could charge $75 for these things and make a huge killing for the same thing.
Old Jan 23, 2004 | 05:34 PM
Sounds good do you have a pic of how yours turned out?
Old Jan 26, 2004 | 10:59 AM
GOFASTER's Avatar
Engine: 388 ci
That is nice and all, but I am talking about the 91-92 style gauges...
Any takers??
Old Jan 26, 2004 | 11:31 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
get sheetmetal.
get the aftermarket gauges
trim it all to fit..
noone makes a bolt in deal for it...
ahtough, if you didnt distroy them, you could use your stock gauges still
none of them went thru the computer except for the speedo... and you can bypass the ECM and make the speedo work too..
Old Jan 26, 2004 | 12:11 PM
xpndbl3's Avatar
Car: 1984 Z28
mr. dude i complete agree, however i switched to all autometer due to lack of accuracy within the factory guages. my tach read 1300 when my autometer said 650 RPM, and i know what an idle sounds like you know? also he should really just take a stencil and copy the factory cluster shape and cut it out with a sawsall, grinding whatever and buy some hole saws and he'll be done quick enough.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
kah992
Aug 19, 2015 02:55 PM
