Head Light relay?
Old Jan 29, 2004 | 04:58 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
Head Light relay?
Help!
I've lost all power to my headlight motors and I can't find the problem. I've read about a relay or logic module that may be the problem. but I have no idea where they're located on the car. Can anyone help?
Old Jan 29, 2004 | 09:10 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Check the fuses first. If you lost power to both at the same time I would check that. If not the fuses check the fusible links.
Being that your sig says 3.1L I assume you have a 90+ car. Your headlights are controlled by a module found on the driverside firewall near the brake booster.
Matt
Old Jan 29, 2004 | 10:33 PM
mmcdjs's Avatar
Engine: 3.1 V6
you wouldn't happen to have a pic of that relay? I have several on the firewall next to the booster. I know that one is for the fans, but there are a couple more there too.
Old Jan 30, 2004 | 12:26 AM
Matto'85TA's Avatar
I dont have a pic of the relay. It will be bigger than the other relays. I think it has GUIDE stamped on it or something.
Matt
Old Jan 30, 2004 | 12:54 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's a roughly 3" x 3" square unit with 2 harness plugs to it located above the brake boosterand as Matt stated, it had 'guide' on it (once removed to see the 'underside'). I'd take a pic to show you but, mine has be relocated to my interior under the dash.
Old Feb 3, 2004 | 05:30 PM
noc_81's Avatar
Mine were dangling beneath the headlight motors in the nose of the car. Just lie on your back looking up into the nose, and you should see them dangling around in there. I pulled mine up next to the motor, to avoide water unning down the wires into them.
Old Feb 3, 2004 | 05:34 PM
mmcdjs's Avatar
Engine: 3.1 V6
hmm. i puled my wires all the the way from the motor to the steering column and didn't see anything. I'm going down to a junk yard tomorrow to climb around in a car they have there.
BRoss99
Aug 10, 2025 05:08 PM
Bert87
Aug 23, 2015 03:50 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Omega
Aug 10, 2015 12:46 PM
