Starting problems
Old Feb 1, 2004 | 04:59 PM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
Starting problems
I'm having problems getting my car to start, it's not really starting at all. It had been sitting for about six months, and now that I've started working on it again, it stopped starting after a couple starts. The battery is dead, but I've got a buddy around who'll help me jump it. However, even then it won't start. The engine starts to turn over, for one or two seconds and then stops. I'm at a loss.
Old Feb 2, 2004 | 01:43 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Get a battery charger and fully charge the battery,don't just jump it). If it is real old I would considder getting a new battery(Geta diehard Gold or something like that). If the car still turns over with no ignition, then you most likely are getting no spark. So see if you are getting spark with a spark tester that you put on the distributor. Your gas is probably real ****ty because it sat that long, so I would put in some good freash gas. To get a car started you need
1. Spark
2. Good Gas
3. Compression
Old Feb 2, 2004 | 02:00 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Thanks for your help, I got it going. All it needed was some fresh gas and some patience on my part. I let it charge for ten minutes then it started right up.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
