B&M Mega Shifter Relay Wiring
Old Feb 4, 2004 | 02:55 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm not going to be installing my Mega Shifter any time soon at all...but I would like to get an idea with what I'm going to be up against. I went and bought the relay needed from Radio Shack today. I looked at the instructions...and wiring up the relay...and looking at the picture really isn't making much sense. I haven't and won't be starting this untill like May or June. Can anyone give me SIMPLE instructions that I can understand? The other switches that came with the shifter look like they will be pretty easy to install....and are explained pretty well in the B&M instructions...but the relay is thowing me off. Here is a picture of the relay....and I can get plenty more pictures of anything....just as long as someone can make me understand this better. Is there only 2 wires that go to this relay...cause that's what I got out of it when I read it. From the diagram on the back...it looks like 4 wires go to it.........Thanks alot guys
Shawn-
Old Feb 4, 2004 | 04:06 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
i thought it was easy to read.. the box with A-F is showing the stock wiring harness. u need to extend thoes wires by about 6in. as an example the "BLK/WHT wire will go to the #5 pin on the relay... and the #9 pin will go to the orange and black pin.
Old Feb 4, 2004 | 04:30 PM
Engine: 5.7
so...are there only 2 wires that go to the relay....or is there 4?
Old Feb 4, 2004 | 06:34 PM
84350camaro's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 355
Transmission: TH350
Axle/Gears: 3.08
You need 4.......basically a relay is something that uses lower current to control a larger current. A small current goes throught one side which contains a coil, which induces magnetism which pulls a switch closed or opens a switch (depends on whether its a normally closed or normally open relay). So it needs 4 wires. 2 to complete the circuit that powers the coil side(lower current side), and then 2 on the switch side to complete the circuit(this side of the circuit is the higher current side). Hope this helps!
Old Feb 4, 2004 | 08:06 PM
Car: IROC-Z
look at the diagram... you see the little box thing twards the right with the zig zag mark in it, that is the relay.
ill tell you where everything goes....
wire A (BLK WHT) goes to pin #5
Wire B (ORNG BLK) goes to Pin #9
Wire C ( DRK BLU) goes to both micro switches. then from the 2nd prong on the lower, that goes to Pin #13
Wire D (LT GRN) goes to upper switch
Wire E (PURPLE) Goes to pin #12
Wire F ( Yellow) goes to pin #8
Then Pin #14 goes to a ground, like a screw or something.
so you have a total of 6 wires.
hope that helps a little bit
Old Feb 4, 2004 | 11:20 PM
Engine: 5.7
that helps a TON man, thanks alot! I haven't and can't even take the top of my shifter plate off to even look at the wires. So....when you say a wire like (BLK WHT) is there only one wire with that color combo? or is there actually 2 wires, one black, one white? And the "micro switch" your referring to, is that the switches that came with the B&M?
Old Feb 5, 2004 | 12:14 AM
Engine: 5.7
sorry, double post
Old Feb 6, 2004 | 06:40 PM
Car: IROC-Z
the (BLK WHT) is a bombo it's a black wire with a white line on it... the switches are the ones that need to be bolted to the side of the shifter. the backup light and such.
I will have a tech artical up at
http://www.iroczone.com soon and mabey http://www.domesticspeed.com
if u need more help with installing it.
Old Feb 7, 2004 | 10:59 AM
Engine: 5.7
alright man....so far, you've been a good help, I appreciate it
Old Feb 10, 2004 | 10:28 PM
Engine: 5.7
well, I went to the junkyard today, and cut out the whole harness just to see what I'll be messing around with. It really dosen't look all that bad....only one thing....In the instructions, it mentions a yellow and purple wire....it has the purple wire....but there is not a yellow wire....there is a green wire (purple and green wires are really thick) does that make sense?
Old Feb 17, 2004 | 07:38 PM
Car: IROC-Z
it sounds right... it's wierd my purpal wire looked more like a brown wire... it should work fine.
Old Aug 22, 2008 | 09:58 PM
NArtissimus's Avatar
Car: 88 Camaro Sport Coupe
Engine: 01 LS1, Xer-281-hr, 1.75 ProMagnums
Transmission: 4L60E, Stg2, SuperServos, 3200 stl?
Axle/Gears: 10blt, Torsen, 4.10, T/A Gurdle
Re: B&M Mega Shifter Relay Wiring
Hey,
does anyone know the part number / model number for the proper relay to do this, like the one in the picture? Or will a standard 5pin relay work for this just the same?
Thanks, Art
Old Aug 22, 2008 | 10:40 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
i wana know too .ive had my mega shifter for sooo long and never bothered to install it . but that part number from radio shack would deffenetly help speed up the procces.
I just dont like that boot its ugly as hell
Old Aug 8, 2012 | 08:45 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
i know its an old post but need to know what relay to get thanks in advance
Old Aug 9, 2012 | 03:39 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Rockyd
... need to know what relay to get.....
Any std 12V NO relay rated 20A+
http://www.radioshack.com/product/in...ductId=3020762
Old Aug 9, 2012 | 08:00 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
So is it a regular 5 prong one because everything I read says 6 wires in and out. That's for the link
Old Aug 9, 2012 | 09:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
All this seems overly complicated
I have a B&M Quicksilver with the similar microswitches and run the starter and backup circuits through them with no problems (>5 years )
Makes sense to have a relay on the starter circuit because of potential current demands but that would only require a reg 4 pin N/O relay
MS on shifter closes in P/N and operates the relay to complete the starter circuit
Old Jan 3, 2013 | 09:46 PM
AggieIROC13's Avatar
Is this the right relay?
http://www.radioshack.com/product/in...ductId=2049720
or maybe this?
http://www.radioshack.com/product/in...uctId=2049722#
Old May 22, 2015 | 08:09 PM
Ironman4life's Avatar
Car: 1984 Trans-am
hope this topic is not to old i have my 84 trans-an with the 700r4 i install the b&m mega shifter in about two month ago love it now i attempted to wire up the neutral lock out and the reverse lights but only got as far as hooking up the purple and yellow wire now yesterday i grab six different colors or wire about a foot long each and tried a attempted at hooking it all up needless to say lol all wires from the original harness are cut and unhooked but now my car will not even turn over no blown fuses or bad starter or bad battery just when i go to turn it over the choke and bat light come on but nothing no clicking or anything like there no starter even there so could some one please tell me what i have done wrong i want my black queen back up and running and the wiring hooked up properly i brought the b&m mega shifter console fit from work came with a relay in the box wiring schematic very similar to the above post from sickness91z28 thank you very much
colton_carlson
Mar 8, 2019 12:21 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
