Right turn signal not working
Old Feb 6, 2004 | 07:30 AM
DustyWusty's Avatar
Car: 89 bird, 86.5 D21 Hardbody duringwinter
Engine: 305, VG30e
Transmission: 700r4, dunno the other one :)
When I turn on my headlights my right blinker is solid green with no clicking and no light from the blinker (on the car). The left works fine but there is no clicking
any ideas? is this common?
Old Feb 6, 2004 | 10:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Most common problem is simply a burnt out bulb. The easiest check it to turn on your hazzards and do a walk around noting which bulb is not lighting. The hazzards will lights/flash all the turn lamps regardless of one being burnt out which lets you see which one isn't working.
Old Feb 7, 2004 | 12:34 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
What kind of car is it on? If it's a Firebird, check the ground connections near the passenger side rad support. My Formula would do that when the lights were on because the connector broke off the end of the ground wire. Fixed that, and it works fine.
specialized
Jun 18, 2022 09:26 AM
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
