Tpi Wiring Question
Old Feb 7, 2004 | 04:04 PM
edge433's Avatar
Car: '01-Z71, 2ND GEN CAMARO, 3RD GEN Z28
Engine: 5.3, 383 STROKER, 350 TPI
Transmission: 4L80E, TH400, 700R4
Tpi Wiring Question
I HAVE A COMPLETE TPI WIRING HARNESS, ECM... I KNOW WHERE ALL THE WIRING GOES FROM THE ECM OUT TO THE ENGINE, ANYONE HAVE A SCHEMATIC OF THE WIRES THAT COME FROM THE DASH TO THE ECM? THERE IS TO CONNECTORS THAT ARE LONG AND FLAT AND ONE SMALLER CONNECTOR. ALL THE WIRES ARE CUT AND NONE OF THEM ARE MARKED. ITS AN 85 TPI. I LOOKED THRU THE POST DIDN'T SEE THIS INFO ANYWHERE. THANKS
Old Feb 8, 2004 | 12:37 AM
Morley's Avatar
First, turn off your caps lock.
One of those connectors (smaller one) is probably going to the the MAS module connector (unless you already have that hooked up) It is a smaller box that piggybacks on the ECM.
Old Feb 8, 2004 | 02:16 AM
edge433's Avatar
Does having the caps lock on make my question unclear? Just wondering??? Thanks for the info.
Old Feb 8, 2004 | 09:42 AM
Morley's Avatar
It makes it harder to read and it is the internet equalivant of shouting or yelling.
Old Feb 8, 2004 | 11:10 AM
edge433's Avatar
Sorry Military, just habit....
Old Feb 8, 2004 | 05:26 PM
Morley's Avatar
NP.
Do you have the MAS module piggybacked on the ECM? And is it hooked up?
Caspar
Jun 19, 2016 11:19 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
