completly rewiring my 84 trans am
Old Feb 7, 2004 | 06:03 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I got offered a 89 camaro with a L98 vette 350 and TBI which has a very clean and unbutchered harness, so I'm going to swap it all over, my questions revolve around what wont work.
for instance I realize certain things on the dash harness may need to be extended but my major concern is the headlights, wiper motor and will it fit, vats wont be a problem since I intend to use the camaros steering column.
the camaro has a cable speedo wich will work fine since my 84's is the same, but the VSS will probably be a issue, will the vss sensor on the back of the speedo mount to my 84's speedo.
any other thing that you all can think of that might be a problem let me know
Old Feb 7, 2004 | 06:45 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
L98 <i> and</i> TBI???
You're in for a lot of work...tracing and splicing wires between the two.
I don't envy you.
Old Feb 8, 2004 | 12:02 AM
Jproz1167's Avatar
petes
no it's a L-98 long block with 89 camaro electronics
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
