power lock click
Old Feb 9, 2004 | 02:41 PM
shaolin's Avatar
Car: 1987 IROC-Z
Engine: 305 tpi
power lock click
ok all electronics gurus, whenever i push the power door lock buttons (driver or passenger side) the locks do not work and all i hear is a click noise coming from what seems to be around the fuse box area? does anyone know what i can do to fix this problem? expensive??
Old Feb 10, 2004 | 04:59 PM
shaolin's Avatar
Car: 1987 IROC-Z
Engine: 305 tpi
no one can help?
Old Feb 10, 2004 | 06:40 PM
jaredjames's Avatar
Car: 1982 Berlinetta
you sound lonely, lol I can't help you and albedamned if anyone else can too. That's really weird, if I were you I would follow the wires from the button to where you hear the noise and see if you don't run into something. good luck
Old Feb 10, 2004 | 07:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well, I'll be nice and try to help you out here. The click that you are hearing from around the dash area is the power door lock relay which is located inside the left kick panel. You can get a new relay fairly cheap and if that doesn't fix the problem of the door not locking, remove the inner door panels and clean and lube the rods that go to the power door lock solenoids which are located inside the door frame at the bottom of the door below the latch. Spray lithium grease is good for this after cleaning it.
Old Feb 11, 2004 | 01:33 PM
shaolin's Avatar
Car: 1987 IROC-Z
Engine: 305 tpi
thanks for advice, where might i be able to get one of those relays? advanced auto?
Old Feb 11, 2004 | 05:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, or AutoZone or NAPA, If not them, they are still available through the dealership or a good junkyard.
Old Feb 11, 2004 | 08:46 PM
88txiroc's Avatar
Before you go out and buy new relays, first try to check the connections. Make sure that they are grounded to the body really well. The screw that holds them in place is also the grounding point. A lot of our cars have P/L that do not work, or work slow. This has helped many people fix those problems.
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
