vehicle speed sensor
Old Feb 9, 2004 | 11:50 PM
AFcamaro's Avatar
My 700r4 to t-5 swap went well, execpt (we all have excepts!) the vss. The t-5 tranny does not have the same vss connectors as the 700r4. does anyone know where the vss connector was on the 85 t-5 tranny's, for t-5 that i put in was a 90and it had an electronic speedo and it was a part of that. I am in the process of buying a 85 cable speedo input for the 90 t-5(lol dont know if i want to, my girl yells when i speed!) and do not see a connector for the vss so the ? is where does my vss go?!!
any help would be appreciated
john
Old Feb 10, 2004 | 12:53 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
First question...what car is this in?
Old Feb 10, 2004 | 11:44 AM
AFcamaro's Avatar
it is in a 85 z-28 tpi (used to be an automatic) but the t-5 i put in is from a 90
Old Feb 10, 2004 | 09:27 PM
3rdGenSS's Avatar
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
the vss is on the the back of the speedo itself in the 85. i have an 86 which is pretty much identical.. i need the electronic vss as i am upgraded to 4th gen interior... care to trade out the cable drive on the tranny for the vss on the tranny?
Old Feb 11, 2004 | 02:56 PM
dd85T/A's Avatar
Car: 85 T/A
The VSS is installed on the tranny. You need a cable driven VSS for your T5. The spdo cable you have now will just screw on the VSS.
Old Feb 11, 2004 | 06:28 PM
3rdGenSS's Avatar
ok from what i have done on mine and looking true diagrams... the vss on the 90 tranny is actually on the tailshaft itself. the vss on the 85 if it is the original gauges is on the cluster. you would need the cable speedo drive that goes into the tranny so it will turn your speedo which in turn goes to the vss to give signal back to the ecm, tach, and cruise. you should be able to find on in a salvage yard as long as it is from a pre 90 t-5 tranny in a camaro. like i said before i do have one and need the electric one from the tranny like yours. any questions let me know
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
Infested
May 22, 2018 11:56 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
GVMV
Aug 16, 2015 08:01 PM
