seat belt warning?
Old Feb 13, 2004 | 12:35 PM
Lizard's Avatar
Car: '84 Z28
Engine: 305 carb
Transmission: 4 spd auto
seat belt warning?
Hi,
The seat belt warning lamp in my '84 z28 has decided to stay on continuously for some reason.I can't find any real info on the "8 second delay" timer in the proper shop manual. Any idea where to look for the thing?..or what it looks like?
I haven't altered anything to cause it to fault as far as I know
Old Feb 13, 2004 | 12:59 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The delay timer is in the same box that the warning buzzer is in. On a left-hand drive thirdgen, it would be located above the drivers' right leg, under the dash on what is called a 'convenience center'. This center also houses the hazard warning flasher and choke heater relay. If your car has been converted to right-hand drive, it's hard to say what wiring has been shifted around, so you can locate it by turning on the hazards lights and locating the clicking sound of the flasher. The box you are seeking should be blck or gray, will be about 80mm long by 40mm high and 25mm thick.
You might also want to check the wiring connector on the lower retractor on the driver's side. Try grounding the black wire and see if that makes any difference.
Old Feb 13, 2004 | 01:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Replace the audio alarm assembly, it is going bad
Old Feb 20, 2004 | 11:32 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
disconnect the battery. then cut the black wire going to the drivers seatbelt. i cut mine and all is well. use a cap nad crimp it on. good luck
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
