Alarm Wireing
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
Alarm Wireing
Hey guys, i got an alphagaurds alarm that has remote start and keyless entry. I got a couple problems with the wireing diagram. #1 if i tap the parking lights in the interior going to the rear lights- will they fronts work too? and #2 it says
Yellow- Start
Red- IGN power
Blue- ACC power
Brown- IGN on
Brown- IGN on
Black- Ground
I have the red going to the Ignition power in the fuse box, the blue going to the accessory and black groinded to the chassis. for the yellow wire where do i tap that? for the brown wires it says "Wire 1- only connect when a second connection to IGN ON is required to start the engine or ACCY, in most cars its not neccasary decision to be made by installer" is it neccasary? then it says Brown #2 connect to air conditioner power supply only- where do they go
and where can i tap into the start wire?
- any help is apreciated! thanks
Yellow- Start
Red- IGN power
Blue- ACC power
Brown- IGN on
Brown- IGN on
Black- Ground
Glowsock
Jan 9, 2017 04:06 PM
