Speedo needle not lighting up.
Old Feb 22, 2004 | 01:03 AM
Catchen22's Avatar
Car: 91 Camaro T-Tops
Engine: 3.1L
Half the Spedometer and the Needle don't light up anymore. So at night I don't know how fast i'm going. EVERYTHING else works fine, RPM, Oil pressure, etc. Actually now that I think about it, when my oil pressure gets to about 60-80 psi it goes wack. The needle flips out and goes way past 80. BUT when I give it the slightest amount of gas the needle goes back to normal. Any Ideas? I figure the Speedometer just burnt out a light or something but I can't figure out the oil pressure guage. The weirdest part is that it only does it sometimes. Like once in 3 days or so, and it will do it all day, only that day.
Old Mar 1, 2004 | 04:35 PM
700r4=junk
Guest
Posts: n/a
EVERY THIRD GEN I HAVE BEEN IN ALWAYS HAS A BOUNCING NEEDLE AT IDLE FOR THE OIL PRESSURE.....IF SOMETHING WAS SERIOUSLY MESS UP YOU WOULD KNOW
Old Mar 1, 2004 | 06:20 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Change the light bulbs in the gauge cluster. That usually helps. As for the oil pressure needle, you're on your own with that one.
Old Mar 1, 2004 | 06:44 PM
91Z28-350's Avatar
1) new bulbs
2) new oil pressure sending unit.
PATRIOTIC1911
Sep 1, 2015 07:26 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
Omega
Aug 10, 2015 12:46 PM
