high beam indicator lamp
Old Feb 22, 2004 | 06:38 PM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Axle/Gears: Stock round ones
Is the High beam indicator lamp for an 86 camaro fused?
Also I have a Haynes manual that has the 84 wiring diagram for the lights and so forth(not for the ecm). I am wondering if that is a basic format used at least through '86 for lights and so forth!
Reason being I need to pass inspection! The high beams work but not the Indicator lamp!
So I pull the lamp out,,,, looks fine,,,,,,, so I replace it anyway,,,, Viola works just great! Now to hook up the cable and put back the screws and headoff to the station in the morn! Later!!!!!!!!!!!!!!!!!!!!!!!!!!!! and of course the lamp is not fused(on it's on circuit) and more than likely the standard diagram is true even for el caminos
Jammer Out
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
